continienzo
Hi all,
I would like to know if anyone tried yet to solve this problem...
Example: you have a topic to read in a category, in forum homepage it show the unread icon.
You go directly into that topic so you read it and you then go back to forum homepage.... it show the unread icon again...
Then if you go into the category to see the topic lists and then back to home it show the read icon...
That is a little annoying... i wold like to know if anyone know how to solve it... or how it does work the unread/read feature to try give it a try...
thanks
Enzo
Jognu
  • Jognu
I also noticed that, it's very annoying !
A fix already exist for the next release ?
Otherwise I will try to do something.
Originally Posted by: Jognu
There will be a new read/unread tracking feature in the upcoming release. Which is not session based instead it used the database to save the last read Datetime. Also the icons should be displayed the correct state.
