arglargl
  • arglargl
  • 52.4% (Neutral)
Hi!
This is my first YAF installation, version 1.9.4, installed via GoDaddy's applications interface to my "Unlimited" Windows hosting plan.
First I should say, the setup went very smoothly, the forum works, looks clean and easy to administer.
Now, I have several domains hosted under this plan. Let's call the one on which YAF was installed "Mydomain".
"Mydomain.com" points to a subfolder of my primary, so in the file system I have:
..\html\mydomain_files
(Btw, the site that resides there is classic ASP.)
I chose to insall YAF to a subfolder of that domain's folder, called "forum", so I have:
..\html\mydomain_files\forum
I also have a subdomain which points to that new folder, i.e. browsing to "http://forum.mydomain.com" will successfully access my forum's default page.
Now my question...
http://forum.mydomain.com/ mydomain_files/forum/{etc}
How is that even resolving? Is there anything I can do to fix it so "mydomain_files/forum" doesn't appear? I'm probably just overlooking something...
p.s. forgot to mention, I added the BaseURLMask to app.config, e.g.
