I had been running an RC1 based install of YAF inside my DNN installation, and when I saw the upgrade to RC2, I went to upgrade. I've tried multiple times to uninstall and resintall, I've check the web.config, I've removed extraneous files from the App_Code folder, and I'm getting the following in my event log in DNN.
I've even tried this with a clean YAF install in a different database, and it's still giving me this error (which means it's a code issue, not a database upgrade issue). I'm totally stuck at this point, and I'm hoping that some of you gurus can work your way through this and help me figure out where to start looking. Thanks!
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. --->
System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.at System.Reflection.Module._GetTypesInternal(StackCrawlMark& stackMark)at System.Reflection.Module.GetTypes()at YAF.Modules.YafModuleManager`1.FindModules(IList assemblies, String moduleNamespace, String moduleBaseInterface)at YAF.Modules.YafModuleManager`1.AddModules(List`1 assemblies)at YAF.Modules.YafBaseModuleManager..ctor()---
End of inner exception stack trace ---
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache)at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks,
Boolean fillCache)at System.Activator.CreateInstance(Type type, Boolean nonPublic)at YAF.Classes.Pattern.SingleClassInstanceFactory.GetInstance[T]()at
YAF.Classes.Core.YafContext.get_BaseModuleManager()at YAF.Forum..ctor()at YAF.DotNetNuke.YafDnnModule.InitializeComponent()at YAF.DotNetNuke.YafDnnModule.OnInit(EventArgs e)at
System.Web.UI.Control.InitRecursive(Control namingContainer)at System.Web.UI.Control.AddedControl(Control control, Int32 index)at System.Web.UI.ControlCollection.Add(Control
child)at DotNetNuke.UI.Modules.ModuleHost.InjectModuleContent(Control content)at DotNetNuke.UI.Modules.ModuleHost.CreateChildControls()at
System.Web.UI.Control.EnsureChildControls()at DotNetNuke.UI.Modules.ModuleHost.get_ModuleControl()at DotNetNuke.UI.Containers.Container.get_ModuleControl()at
DotNetNuke.UI.Containers.Container.ProcessModule()at DotNetNuke.UI.Skins.Pane.InjectModule(ModuleInfo objModule)
Edited by user
15 years ago |
Reason: Not specified
