logan
  • logan
  • YAF Leader Topic Starter
The switching of Show and Hide quickreply doesn't work in newer browsers.
IE8 in IE7 mode works. Newer FF,Chrome, Opera and Safari won't switch the text
The text on the right side of QuickReply when clicked to open the input textarea
should change values, and if using an image for expand and collapse doesn't switch.
Cause of Problem is case sensitive selection with GetElementbyId.
Fix. Source code required
YAF.CONTROLS Datapanel.cs
#914 Change lowercase a in actionlink to uppercase like so
from
this._actionLink.ID = ID + "_actionLink";
to
this._actionLink.ID = ID + "_ActionLink";
And in /resources/js/DataPanel.js
function DataPanel_ExpandCollapseImage(hd, cht, cha, st, ex, cl, tc, te)
	var elImg = (document.getElementById(cha)).getElementsByTagName("img");
	if(document.getElementById(hd).style.display == '')
		document.getElementById(hd).style.display = 'none';
		if(cht != '')
			document.getElementById(cht).title = te;
		elImg[0].src = ex;
		elImg[0].alt = te;
		elImg[0].title = te;//ADDED LINE
		document.getElementById(st).value = 'true';
	else
		document.getElementById(hd).style.display = '';
		if(cht != '')
			document.getElementById(cht).title = tc;
		elImg[0].src = cl;
		elImg[0].alt = tc;
		elImg[0].title = tc;//ADDED LINE
		document.getElementById(st).value = 'false';
Rebuild YAF.CONTROLS and all is well. Text, Images and Tooltip will switch correctly.
IE7 places the post button on top of the textarea fix
resources/css/forum.css change from 100px to 100%
.yafnet .quickReplyLine
	padding: 5px 10px 5px 5px;
	height:100%;
HTH
test
Thanks, logan. I've applied it to svn. It seems to work fine with all browser versions 🙂.
